Power button and other keys won't respond
No worries, it's not the usual won't boot issue. I googled for my prob night and day. Atm the book runs without battery.
1. When I plug in the MacBook Pro Mid 2011 into a power socket it starts fine, but not due pressing the power button. There is nothing. Same for shut off. Can shut down via Software (Mavericks) but the power button is "dead".
2. Letters and numbers won't respond. The function keys work and some of the "edgy" keys, enter, shift, arrows. But not the normal letters and number. I'm using an external keyboard atm.
The track pad works fine.
Thanks for any help. I can't solve this issue. Tried all the common key combination magic tricks. No success.
Thank you
3条评论
Has anything happened to your Macbook that you're aware of?
由 Gary 完成的
Thanks for your comment. No, not as far as I know. What's puzzling me is that some keys are working, I even re-seated the ribbon cable to be sure that this is not the culprit. From the numbers only the 0 responds, no letter, but all the function keys work. The external keyboard works fine. What do you think about cleaning with 99% isopropanol? Is is worth a try?
由 Jens Richter 完成的
Without taking the top case off you really can't clean it effectively with Isopropyl alcohol without putting the rest of the system as risk of damage.
由 Dan 完成的
