跳转到主内容
Repair and troubleshooting information for the Suzuki FA50 Moped.
75 个问题 查看全部
no acceleration,starts hard,need help
Bike starts hard and bogs on accelbcleaned carb,good spark etc...
Please help.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
1条评论
I have the same problem, but my 50cc vip will only idle and thats at full to half throutle have tride 2 different brand new carborators, new top end rings the whole bit but same problem.
完成的
添加一条评论
8个答案
最有帮助的答案
How old is the gas in the tank ?
is it ready mixed or does the oil pump work (is the oil tank full?)
if the gas is older - change it, use the ready mixed one.
这个答案有帮助吗?
得分 2
添加一条评论
I had the same problem, turns out the exhaust was plugged.
the previous owner was running with oil in oil tank AND premixed fuel creating quite a carbon deposit in the exhaust and oil. Cleaned it with a wire coat hanger and burned out the rest.
这个答案有帮助吗?
得分 2
2条评论:
A clogged exhaust will make you think the motor is being choked . It actually is being choked , just from the wrong end . ;)
完成的
Can I have fa50 run without a fuel filter
完成的
添加一条评论
Could be that you are running super rich on your fuel/air mixture. Try leaning it out.
这个答案有帮助吗?
得分 1
添加一条评论
You shoulddefinitely adjust the idle and air mixture screws if your FA50's not running well. Take a look at the carburetor diagram and make sure that the air mixture screw is 1 3/4 turns, as instructed, and that the idle screw is adjusted properly.
Honestly, I wasn't able to figure out how to set the idle to "1500 +/- 150 RPM," so I just ran the bike until warm and then adjusted the screw until it "sounded right" -- whatever sounded like it should be going at.
Also, make sure that the choke cable is completely off when running the bike, and especially while adjusting the idle / air mixture screws.
这个答案有帮助吗?
得分 1
添加一条评论
you might want to check the compression. it should be between 100 to 125. if its low rebuild is in its future.
nick
这个答案有帮助吗?
得分 1
2条评论:
Mine was 30 so I put a bore kit on it now I'm rebuilding the carb because it sat for 5 months
完成的
mine is 90... cant keep it running. does it need a bore kit?
完成的
添加一条评论
Make sure your transmission oil is clean if the acceleration is bad after you adjust the mixture. You'll be amazed how much this can slow you down.
这个答案有帮助吗?
得分 1
1条评论:
Clean AND the correct oil as recommended in the manual .
完成的
添加一条评论
If it smells rich you may want to change the spark plugs. Easy to do and should be done before mucking around with carby mixture. If you have had bad fuel your spark plugs suffer.
这个答案有帮助吗?
得分 0
添加一条评论
What is the trannys fluid? And recommend oil? Any 2 stoke oil?
这个答案有帮助吗?
得分 0
1条评论:
Trans oil use 10w30 synthetic, and use injection found at your local cycle shop, do not use 2 cycle oil you put in your chain saw or weedeater.
完成的
添加一条评论
添加你的答案
darren 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 13
总计 10,018
