跳转到主内容
Repair manuals and information for the Microsoft Surface line of tablets.
128 个问题 查看全部
Can I repair a broken display without replacing it?
Hey guys!
I dropped my Surface RT what led to a broken glass in one of the corners.
The functionality of the touch display is not disturbed (except one little part on the left side).
As a new display is quite expensive i would not like to replace it.
But I am still afraid that some kind of moisture or water or sth. elese could get into the display...
My question is can i repair the broken point with some kind of glue or whats the best way to protect it from more damage?
Thanks a lot for reading this!
greetings Manuel
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
最有帮助的答案
Manuel, there is really no way of fixing it. So, for a permanent resolution you will have to replace it. As a temporary solution you could use part of a screen protector to cover the area, or use clear double sided tape on that area only. Hope this helps, good luck.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Manuel 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 556
