跳转到主内容
The HP Pavilion dv2000 Notebook PC is an entertainment based PC produced in 2007.
23 个问题 查看全部
Why my power adapter is overheating along with my battery?
many a times when i charge my laptop with its charger the temperature of my battery along with the temperature of my charger gradually increases even if i do simple task like browsing.What is the reason and what should i do.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
Bibhu Prasad, your power adapter gets hotter as it tries to supply the power demand to your computer. Make sure that your air inlet vents are clean and free of obstruction. You may also consider disassembling your computer and cleaning the fan. Check to see if it works properly. Depending on the age of your computer, considering a new battery may be another option. Hope this helps, good luck.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Bibhu Prasad 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,731
