Power Supply is damaged
I have had a client that a roach went into the power supply of the PS4 and damage the components. I have been trying for some time now to see where I can obtain power supply separately. Any suggestions? Please contact me at c.fl
14条评论
Has your client contacted Sony to see if a warranty replacement is valid?
由 Wade 完成的
No she has not, also the warranty seal already been removed. The ps4 was infested with a small colony of roaches by the time I got to it.
由 Charles 完成的
I think she has bigger issues than the PS4 power supply.
Anywho, researching your question more. Are you referring to the external power brick or the power inlet on the back of the console?
由 Wade 完成的
I was speaking of the power inlet in the back of the ps4. And no there is no bigger issue I had obtain another ps4 from a friend and switch the PSU and the broken was able to start up.
Dakota I will go ahead and try what you mentioned. I'll post back if I find anything
由 Charles 完成的
Actually I was referring to the roaches being the bigger issue.
由 Wade 完成的
显示更多的9条评论
