跳转到主内容
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
2521 个问题 查看全部
No Service after repair! :( Might have broken a component.
The phone worked fine before I did the repair, but I believe I may have broken a component on the board with a screwdriver. Can someone tell me if this component in the photo is related to cell reception? And which components I should look at to determine if they may be damaged?
And is there is an easy way I can go about fixing it?
Thank you to anyone that might offer suggestions.
http://www.imgur.com/Mo3Z6T0
EDIT: Now I found another component that appears damaged, couldn't his one be the culprit?
http://m.imgur.com/SWMfwOh
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
My 5s fall down display broken .. I replaced display but showing no service. What is the compliant. Which part become complaint
完成的
添加一条评论
4个答案
已选择的解决方案
Cameron,the first image shows C201 missing. That is a 56PF 6.3V 5% capacitor in a 01005 package. It is part of your CG flex connector circuit. The second image shows C242 missing. Coincidentally enough, that capacitor has identical values and is part of your headphone detect circuit. Neither one of those is directly related to your reception circuit. As for fixing it, sorry no easy fix. Those components are rather small and require special tools and skills to be replaced. Hope this helps, good luck.
这个答案有帮助吗?
得分 4
添加一条评论
My only question would be did you try turning the phone on again? like does it still work? I am curious because its hard to tell from the photos what your indicating.
这个答案有帮助吗?
得分 0
2条评论:
Yes it works fine.. Everything works on the phone except for the reception. But I cannot figure out why.. I have already replaced all components related to the cellular antenna (like the lightning connector assembly) and screws holding antenna to the frame.
完成的
Can you detail all you have done or upload a little bit clearer pictures? I apologize my eyesight is horrible. It looks like you may have broken it but i would need a clearer or bigger picture to be absolutely sure.
完成的
添加一条评论
You should carefully clean all the connectors and make shure that tey are well clipped. It happened to me on an iPhone4. The + volume button was the only one that was not working, so ... check and clean conections !
Second option ont he same iPhone 4 after a screan change the repair man had to connect and disconnect the iphone to itunes (or maybe a special soft) to make the service back again. He was aware about this sublety and make the service work just after the repair
这个答案有帮助吗?
得分 0
添加一条评论
usually they are resisters and its hard to determine the resistance. a alternative would be to jump add a jumper.
use flux and a soldier iron and some vary little solder and bridge the connection.
be sure to disconnect power and remove battery from area were you will be applying heat.
always remember to take your time.
这个答案有帮助吗?
得分 -1
添加一条评论
添加你的答案
Cameron 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 9,368
