跳转到主内容
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
2522 个问题 查看全部
No cellular service on my iPhone
After the screen repair my iPhone's could not find my cellular network. I have tried to do everything to fix it but nothing worked. So I decided that i am going to replace the cellular antenna, does any one know how to or have a link to a nice guide?
i found the component i need
iPhone 5 Cellular Antenna
any ideas?
iPhone 5 Cellular Antenna图片
产品
$9.99
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
Did u take the battery out? Only reason I ask is there could be pry damage If you did.
The antenna you are looking for is attached to the dock and Is the little black thin wire that clips into the bottom of the logic board make sure it's still plugged in..
If it was only a screen replacement then you should not have damaged this part
Also make sure the two long black cables that run up the middle of the logic board are clipped in
这个答案有帮助吗?
得分 0
5条评论:
I didn't take the battery out, all i did was disconnect it.
i made sure and every things seems to be plugged in good ;/
完成的
There are little componants all around were the battery connector is my guess is you have knocked one off
完成的
so you think its the motherboard then?
完成的
It could be I would open up and inspect for damage around the battery connector
完成的
I inspected it very carefully, I see nothing that's not normal.
完成的
添加一条评论
添加你的答案
Jon 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 729
