iPhone 5C no power
Just simply has no power. I disconnected the battery cable and plugged the pghone into my computer but no apple logo flashing. No signs of power at all. Could rthis still be a bad battery?
I would most certainly replace the battery. 9/10 you will get some kind of life.
Here is a link to the battery.
Jonny
这个答案有帮助吗?
I will try a new battery. I read around the the USB charging IC (U2) would go out often with the no-power iphone 5's when plugged into a cheap crap china charger or cord. (iPhone came with a pink trash sync cable...) TY Ill try it
sounds more like your U2 iC meaning it needs a main board repair.
easiest way i find to identify this is to disconnect battery and plug in as normal to mains or pc. if apple logo appears and goes off then your board is fine. if nothing appears then its an ic issue.
but yeah cheap cables are a major contributary to this
If the screen has just been replaced it could be a number of things
Battery or faulty screen
这个答案有帮助吗?
I had the iphone plugged into my computer for about 3 hours and nothing. Phone doesnt even warm up. Thnx
First thing to do is replace the battery if the battery is completely dead even iTunes won't pick it up
Jonny were u from mate?
Ok, I'll harvest a battery from another 5 I have tonight. And sorry, I don't know what you mean "from mate". Thnx
Well...so much for that -_-...adhesive strips snapped right off immediately on the iphone I was gonna harvest the battery from...a new iphone 5C battery on the way Ill update what happens.
i have an iphone 5c and i was putting on credit then it has been saying please wait for a long time so i pressed the on and off button for a long time then it turned off and would not turn on back so i dont know what to do and the battery was at about 94 percent
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 6,973
1条评论
Oh ya, no water damage, screen has been replaced, dont know the backround.
由 Jonny 完成的
