跳转到主内容
修理汽车、卡车部件指南,包括引擎。
62 个问题 查看全部
Why is gas mixing in oil in 2004 Kohler CV740s engine?
when it cranked up it blew gas and oil out the breather on the valve cover approx 6 feet and leaked down on the muffler and caught on fire. I put it out but don't understand what caused it. How do I repair it?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
3条评论
How did you have the engine stored? Did your recently transport it. Check your float valve and see if it is stuck open.
完成的
No it was in my carport since last fall and I went to crank it and it blowed gas out of the valve cover about 6 feet and dripped down on the mufler and caught on fire. And I mean a big fire put a lot of water on it to put it out. But i am afraid to try it again without knowing what caused it. My oil case also has about gal. of gas in the oil. don't know if it might be intake crack or head craked or something else? Thanks, Charley
完成的
Thanks so much, i am unable to check it until this weekend but I will . Let you know what I find out. Thanks
完成的
添加一条评论
2个答案
已选择的解决方案
See if the freeze plugs are blown out or bulging out.
这个答案有帮助吗?
得分 0
1条评论:
I don't think so. thanks, Charley
完成的
添加一条评论
最有帮助的答案
frankly, I'd start by draining all the fluids (oil and fuel) Check your fuel lines, gas tank, air filter. Change your spark plugs and set your valve clearance. You may also consider a leak down test to see if you have a stuck intake valve which could be causing this. Check your float valve and make sure it is not stuck, as well as your float level. You can get the service manual for your engine from here.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
frankly 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 853
