跳转到主内容
修复你的物品
维修的权力
配件 & 工具
iPhone 3G是第二代iPhone。型号A1241,有8或16 GB容量,和炫酷的黑色或洁白的白色塑料背面。修复比第一款iPhone更简单。需要螺丝刀、撬撬工具和吸尘工具。
1505 个问题 查看全部
Is there a way to test the motherboard is working?
I've got a faulty iPhone 3G which doesn't turn on or anything, has cracked up screen. Before buying a new LCD I want to be sure the motherboard isn't broken, is there a way to know? The only thing I've had is a noise from the iphone when connecting it to a PC.
I've also powered it from a 4.1v LiPo cell because the battery inside wasn't working, hoping that's ok? (a bit confusing as there are 4 contacts)
Thank you very much
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
LCD iPhone 屏幕维修套装
预算选项,涵盖在我们的终身保修中。
购买套装
LCD iPhone 屏幕维修套装
削减维修成本,而不是质量。
购买套装
2个回答
If you know someone who have a iPhone 3G or some repair shops would like do a favor, there is a easy way to check. Exchange your display and rear case assembly respectively with another working well iPhone 3G, and can make sure which part of the phone have problem.
Good luck to you!
这个答案有帮助吗?
得分 0
添加一条评论
Leo,for a brief connection use the outermost contacts. "a noise from the iPhone when connecting it to a PC." is a good thing. At least your computer recognized it. I would see if iTunes recognizes it. Yes, it may just need a new LCD but there is a lot of other things that could be wrong with it. It's a bit of a crapshoot. Hope this helps, good luck.
这个答案有帮助吗?
得分 0
评论:
Thank you.
Outer most contacts ok, hope I didn't break it by connecting it to the inner contact briefly...
I've bought another spares iphone to swap it's LCD check if that works.
Also it did connect to itunes only there was a passcode, is there a way to get by the passcode? (emailed the seller and he doesn't know it either)
Thanks again
完成的
添加一条评论
添加你的答案
Leo 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 1
总计 178
