跳转到主内容
型号A1367,闪存容量:8、16、32及64GB
915 个问题 查看全部
Can't complete screen repair
I am on my second replacement screen. after successfully replacing a broken screen, when attempting to get the screen completely back together, I broke the replacement screen.
I now have the second replacement screen in, and still can't get the unit to close up tightly. I got new adhesive and applied it, but the screen won't seat correctly.
Any ideas?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
4条评论:
the chrome sides of the replacement screen? Can the clip that gets added back to new screen possibly be slightly off? That should hold screen in, correct?
完成的
I broke it again. Second replacement.
完成的
No not the screen the iPod chrome itself where the screen fits into check that the corners are bent in slightly. You don't need to replace the metal bracket if you don't want to but it will hold the screen in better if installed..
If installing with it fit the top of the screen first but put screen at a little angle to clip the metal bracket in you no what I mean..
完成的
I'm in the Boston area.
完成的
添加一条评论
2个答案
The chrome sides bend in slightly when damaged occurres these will need straighted out and screen seeded in gently to make sure of a perfect fit there is no rush just bend and check if fitting correctly if not bend again..
Once your happy it's going to fit then you can put the adesive on hope this helps
这个答案有帮助吗?
得分 0
1条评论:
Bummer were are you located Ron ?
完成的
添加一条评论
You have a bent frame. Find the defect and make it 100% square--I use a Dremel tool and just file it down.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ron 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 114
