跳转到主内容
The first FWD car to be exported to North America by Volvo
7 个问题 查看全部
How do I tighten my parking brake?
Currently, my parking break slows the roll of my car when I am in neutral. I need the majority of the stress to be on the break and not the transmission and my break is just not doing its job. It pulls all the way up and supplies little braking, if any. Is there a way to remedy this without taking wheels off?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
Nick,
Check this out from an 11 year Volvo mechanic, I would tend to go with that answer, even thought I didn't write it.
Regards,
Frank
这个答案有帮助吗?
得分 2
2条评论:
The method described there is the exact same as in my Saturn ION. Definitely the easiest way to make normal parking brake adjustments.
完成的
Park brake adjustment on 2004 jeep Cherokee - disc brakes ?
完成的
添加一条评论
To adjust the tension screw in the center console, you'll need a Torx 50 bit (and a right angle attachment - it's a tight space).
这个答案有帮助吗?
得分 0
1条评论:
How do I enter the center console ?
完成的
添加一条评论
添加你的答案
Nick Howell 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 6
总计 6,932
