MacBook家族于2006年5月发布,替换了iBook来作为苹果消费级笔记本的产品线。
4114 个问题 查看全部
Service battery after cold temperatures?
Hi, I have a 2006 macbook with a aftermarket battery that I got off amazon for $20. The battery works perfectly when I leave it in warm temperatures but when I bring the computer outside (even when it is off) it looses its maximum capacity from 5462 mAh to 4021 mAh. Its factory maximum capacity was 5600 mAh.
Also, the macbook shuts off at 25% battery no matter what and it will not turn back on without the magsafe adapter.
Any ideas or explanations?
Thanks, Ted.
已回答! View the answer 我也有这个问题
这是一个好问题吗?
按维修分数 0
评论:
How cold is cold?
from about 20 degrees Fahrenheit to 40 degrees Fahrenheit. Im in northeast ohio so it usually is cold outside at this time.
the battery was manufactured 12/28/13 and has 12 charge cycles on it
添加一条评论
所有超过US$100或包含 Pro Tech工具包的订单免费送货!
浏览我们的商店
1个答案
已选择的解决方案
Ted Mayer, sounds about right. Remember that " Cold temperature increases the internal resistance and diminishes the capacity. Batteries that would provide 100 percent capacity at 27°C (80°F) will typically deliver only 50 percent at –18°C (0°F). The capacity decrease is linear with temperature. The capacity decrease is momentary and the level of decline depends on the battery chemistry.The performance of all battery chemistries drops drastically at low temperatures. At –20°C (–4°F) most nickel-, lead- and lithium-based batteries stop functioning. Although NiCd can go down to –40°C (-40°F), the permissible discharge is only 0.2C (5-hour rate)" from here.
这个答案有帮助吗?
按维修分数 2
添加一条评论
添加你的答案
Ted Mayer 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 220
