跳转到主内容
苹果发布了MacBook Pro 15英寸一体化机,采用新的铝质表壳,由单个铝块加工而成。
3090 个问题 查看全部
2 black horizontal lines in the middle, MBP 2008 15"
Hello!
So my MBP has 2 constant black lines in the middle around the apple logo. It wont show on external display though.It boots normally. Did the pram and smc reset. Now i dont know what's next. Should i look for a display, or is there anyhing else that can be done? Help much appreciated.
Thank You!
Cameron
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
Cameron H, single lines across an LCD are usually caused by TAB errors within the LCD panel circuitry. They are very difficult, it at all, to repair. I would suggest a replacement display. Of course, you want to make sure that all the cables are properly connected etc. Hope this helps, good luck.
这个答案有帮助吗?
得分 0
1条评论:
Thanks a lot. Will check cable. Hope to have some luck:)
Have a nice day. :)
完成的
添加一条评论
添加你的答案
Cameron H 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 85
