跳转到主内容
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
3367 个问题 查看全部
No service after water damage iPhone 5
Hi,
I have a water damaged iphone 5. I've cleaned the logic board and changed the screen. The iphone has now NO SERVICE. When i put the sim in, i have to give my code and then the iphone start searching after a minute "no service"
I've tried with other antenna without succes.
What causes this problem and how do i fix this?
thx
已回答! View the answer 我也有这个问题
这是一个好问题吗?
按维修分数 4
评论:
Baseband is fine, thx for the reply
添加一条评论
Android 维修工具包
A new screen or battery is one kit away.
现在开始购物
Android 维修工具包
现在开始购物
4个回答
已选择的解决方案
Water damage is horrible you don't no what part it's wrecked.
you could buy all the parts and it still might not work. Motherboard damage is mostly the cause
Update
Have you tryed a restore?
这个答案有帮助吗?
按维修分数 1
添加一条评论
最有帮助的答案
Check in the system setting to see if the IMEI and ICCID are properly displayed, if they don't display, the baseband is not powered up or fried.
Then we go to RF check, check for visual damage and power on the transceiver and each amp, signal routes for each band, the details can list more than 5 pages so it is a tiring process
这个答案有帮助吗?
按维修分数 5
评论:
Where can I find the 5 pages ?
添加一条评论
I will assume you've ruled out a time/date thing after battery disconnect. Toggle airplane off/on and connect to WiFi.
Last one I had like this was latte damage that I had to desolder the SIM tray to see, it ended up a baseband power ic problem and I gave up. The next one freaked me out with the same behavior so I thought it would be the same. It was jailbroken so hard to see the carrier info. I worried about it for half and hour before I realized it was the silly time/date thing.
keep us posted when you figure it out.
jessa
这个答案有帮助吗?
按维修分数 1
添加一条评论
Putting it in a bag of rice won't clean the logic board. Clean the logic board with isopropanol and check again
这个答案有帮助吗?
按维修分数 -1
添加一条评论
添加你的答案
Mattis 将永远感激不已
浏览统计数据:
过去的24小时: 5
过去的7天: 24
过去的30天: 93
总计 37,846
