跳转到主内容
Second generation of CDMA iPad 2 with 16, 32, or 64 GB and Dual Core A5 Processor. Model Number A1397. Repair is detailed and requires heat and prying.
52 个问题 查看全部
replaced screen on iPad 2, now screen doesn't display anything
I have recently replaced my iPad 2 screen. It all went well (I thought) however after putting back together and turning on, nothing is displayed??? I can see that the screen is lit but very dim. When plugged into laptop I can see the iPad and it all seems to be working fine. It makes the click noise when I lock the screen also. but its just blank.
I've tried to reboot it - holding home and lock. also restored it to factory. still nothing.
Please help!
THanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
最有帮助的答案
It seems to be a backlight issue, have you tried another Screen/Digitizer?
这个答案有帮助吗?
得分 1
添加一条评论
Did you forget to reconnect the LCD cable to the logic board?
Or
Made sure you pushed the connector all the way in?
If that doesn't fix your problem you could try to replace the LCD?
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
brettheidy 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 10
总计 245
