The fourth Google Nexus smartphone, released November 13, 2012.
88 个问题 查看全部
My digitizer is broken but the LCD still works.
The glass is shattered on my screen and the digitizer is totally non responsive (I can't even touch the screen to turn the phone off). Is it worth buying just the glass+digitizer? or should I just buy a whole new LCD unit? Obviously the former is cheaper, but I worry that removing the glass from the LCD will be a pain in the arse.
已回答! View the answer 我也有这个问题
这是一个好问题吗?
按维修分数 0
添加一条评论
所有超过US$100.00或包含 Pro Tech工具包的订单免费送货!
浏览我们的商店
1个答案
已选择的解决方案
Chris, you are absolutely right. To separate it is a royal PITA and I would go with a complete assembly. Remember that there are people out there that will buy your old display assembly for as long as the LCD works. So put it on ebay or something like that and see if you can recover some of the money spent on the assembly. Hope this helps, good luck.
这个答案有帮助吗?
按维修分数 1
评论:
Yea, that's kind of what I figured. Thanks for your response.
添加一条评论
添加你的答案
Chris 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 622
