跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
2191 个问题 查看全部
问题已关闭
Restore problem on replacing battery
I replaced the battery in my 4s and then went to charge it it told me to connect to iTunes and when I did told me to do a restore and update whent through the process and then it has a error code of 21 and can't do the restore any suggestions?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
最有帮助的答案
Error 21 is a battery fault had it many many times before.
The battery you got is defective
这个答案有帮助吗?
得分 1
添加一条评论
check the voltage of the battery in case it was flat?
这个答案有帮助吗?
得分 0
添加一条评论
I've found a guide about "how to restore iPhone 4s after iOS 8 update".
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 120
