跳转到主内容
型号A1367,闪存容量:8、16、32及64GB
915 个问题 查看全部
问题已关闭
iPod touch 4 will not power on...didn't turn off screen before unplug
So, by mistake, I didn't turn off the ipod before I unplugged the screen. I was testing it to see if I had the digitizer plugged in correctly and when I noticed I didn't, i just unplugged and went to working on it. Not remembering to turn it off first. now the ipod will not power on. Any suggestions?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
4个答案
Possibly shorted something. Have you tried a hard reset on it with all cables attached?
这个答案有帮助吗?
得分 0
添加一条评论
are you sure it's not turning on---i.e. iTunes does not recognize it? It would be much more likely that it's just a backlight problem.
这个答案有帮助吗?
得分 0
添加一条评论
I meant to update this sooner. I just unplugged the new screen,let the battery die and when I plugged it back up and ten plugged the device in, the screen powered on as normal. Not sure what caused it to do that, but I'm glad it's working now. Thanks guys!
这个答案有帮助吗?
得分 0
添加一条评论
April how long did you wait for your battery to die? I am in this same situation and I dont know what to do..
这个答案有帮助吗?
得分 0
1条评论:
Lauren--letting the battery die out is the same thing as doing a hard reset---hold the power and home button for 10 seconds.
A hard reset often solves a lot of iDevice problems. If a hard reset doesnt solve, your next step is trying with a known good screen--i.e. your old screen to make sure the problem isn't a defective new screen or torn/damaged flex cable. If that fails to solve, then think backlight problem on motherboard.
jessa
完成的
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 513
