跳转到主内容
2006年十月在北美发布(然而2021才翻译。。15年的坑)
289 个问题 查看全部
My wii don't start up
Hi,
My wii gives me an error, i don't remenber how, and then i turn off my wii and it never sart up again. when i power on my wii stays in black screen.
Is it an way for start up by an sd card with some specific software or else do a reset that comes back the factory memory?
Thanks,
Vitor
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
最有帮助的答案
Either your WiFi module or bluetooth module is broken, or the contents of your NAND flash inside the unit are corrupted. You can try swapping out the two modules with those from a working device, but if that doesn't work, you will have to send it to Nintendo for repair (or replace the main board). There is no way for you to repair the flash memory yourself.
Nintendo Wii Motherboard图片
产品
$44.99
这个答案有帮助吗?
得分 1
添加一条评论
This may or may not be the same problem/solution, as your problem doesn't have enough detail.
Wii console input output doesnot work
这个答案有帮助吗?
得分 0
添加一条评论
Occassionally our Wii console won't power up, no lites or anything. I found that unplugging the power supply for abtout a minute has solved it so far.
Anyone have any ideas about a more permanent fix?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Vitor Leite 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 13
总计 2,903
