跳转到主内容
修复你的物品
维修的权力
商店
无线连接并控制您的苹果电脑。
101 个问题 查看全部
Keys seems to be permanently pressed not even able to enter password
Hi,
I have wireless keyboard for iMac. It suddenly stopped working properly. When I enter password, it would not work. When I press power button, it will start working randomly and keep on entering some alphabets / numbers automatically. I ALS tried to enter password as soon as I turn it on, but it would not work. Looks like only some of the keys are working automatically.
Please help me what could be problem and solution, if you can suggest.
Thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个回答
已选择的解决方案
Replaced the batteries - if not do so. Sometimes strange things happen as battery power gets low.
If this answer is acceptable please remember to return and mark it.
这个答案有帮助吗?
得分 1
评论:
First thing I did was replace the batteries. However problem still remains.
完成的
添加一条评论
最有帮助的答案
Ok, this is a glitch in the keyboard. I have this same keyboard, and I fixed it by hovering a magnet over the top of the keys. While you're doing this, the keys will type on their own, but the stuck key should stop typing!
这个答案有帮助吗?
得分 2
评论:
Neat trick! How did you think to try that?
完成的
It's all about knowing the design of the keyboard. The keys on the keyboard are metal, and the circuit boards are magnetic (electromagnetic to be specific). Therefor, a way of resetting the keys are to hover a magnet over it!
完成的
添加一条评论
添加你的答案
Prashant 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 380
