跳转到主内容
修复你的物品
维修的权力
商店
Repair information for the 7" Android tablet by Samsung. Fixing this device is straightforward, and requires only common tools. The Samsung Galaxy Tab is an Android-based tablet computer produced by Samsung. The 7-inch Samsung Galaxy Tab is the first model in the series. It was introduced on September 2, 2010
143 个问题 查看全部
My Galaxy tab 3: I inserted micro SD.
My Galaxy tab 3: i inserted micro SD. the device appeared on the storage memory, but the galaxy tab dent use it for storage . it keep saying no enough memory???
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个回答
The galaxy tab thinks that an inserted SD card is for media storage alone, none of your apps will transfer to there. In short, and SD card is only for the device to use and not the user.
If this helps, don't forget to mark this answer as Accepted!
这个答案有帮助吗?
得分 0
添加一条评论
My samsung tab3 says my sd card is unmounted I dont know why
这个答案有帮助吗?
得分 0
评论:
I've got the same problem and can't find a solution either.
完成的
添加一条评论
添加你的答案
Ahmed 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 1,556
