跳转到主内容
iPhone 3G是第二代iPhone。型号A1241,有8或16 GB容量,和炫酷的黑色或洁白的白色塑料背面。修复比第一款iPhone更简单。需要螺丝刀、撬撬工具和吸尘工具。
1158 个问题 查看全部
问题已关闭
After replacing the battery, phone wont hold a charge-what is problem?
after replacing the battery, the phone would no longer power up or respond to any button pushing.
i tried soft reset, hard reset, plugging it into the computer, letting it charge... everything. the phone is still an expensive paperweight.
the only response i can get from my phone is when plugged into a wall outlet. when i press the power button, the apple appears for about 15 seconds and then goes black. after going black, you can see where the screen appears to be on for just another second or two (like a screen burn on old tvs) and then it goes completely black (like the phone is off)
Please help
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Looks like new battery is not working or not connected to mainboard.
Howto test :
Plugin to charger. Unplug it when you see the apple logo.
If it goes black after unplug it means new battery is not good or not well connected to mainboard.
The good battery should still show apple logo after unplug the charger.
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 123
