跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
2193 个问题 查看全部
问题已关闭
other pepole can`t hear me
i have a problem with microfone, i can`t hear nobody, i already change the dock with microfone complete new and this option don`t help me. I need change something else? where?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
4个答案
已选择的解决方案
If people can hear you it's not the audio ic chip
I would try another chat hour port it's possible you bought a faulty part.
Try this when you get new part see pic
Actually install it directly without taking the charging port out then insert battery and start up phone the make a call and see if that mic works
It saves you time from taking phone apart if part doesn't work..
I do this with most repairs it saves time if parts faulty
这个答案有帮助吗?
得分 0
添加一条评论
最有帮助的答案
If you can't hear them either and they can't hear you there is a problem with you audio ic chip.. Try this
http://m.youtube.com/watch?v=prSZ9yJnofY
这个答案有帮助吗?
得分 1
1条评论:
i try this think and dont help me,
this is what i do for try fixit:
1 change complete connector dock with new mic
2 follow your advies
the strange is i change all things and still the same, i mean i ear the people btu they can t ear me, if i talk hands free they ear me fine or by viver skype etc, what i need to do more?
完成的
添加一条评论
Definitely start with with Con's link. Also, new dock connectors typically have bad mic's. For whatever reason they have really high failure rates. You should check the return policy.
这个答案有帮助吗?
得分 0
添加一条评论
I go try that again like you say, with new part, because I have done at begin, change all dock part inc mic, so I go buy a new item I will try again once thanks I let you know what happens then
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 131
