跳转到主内容
型号 A1238 / 80, 120, 或 160 GB 硬盘 / 黑色或银色面板
904 个问题 查看全部
问题已关闭
Music doesn't play out my left speaker/earphone unless I squeeze it
Basically, when I play a song on my iPod Classic, the music only plays out of my right earphone unless I squeeze the iPod and then the music will also play out the left earphone.
I regularly have to squeeze it because the left headphone will stop working after x amount of time.
The earphones work fine. I have tried plugging the ipod into my car stereo and the same thing happens ( Using the charger cable not AUX) I still have to squeeze it so that the music plays out of the left speakers.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi Matt,
It sounds like the mini-jack connector in the iPod isn't working properly. It could be that the connector in the iPod that connects the mini-jack cable to the motherboard is loose. But it is also possible that the mini-jack itself is just broken and needs to be replaced.
You can replace it using this guide:
iPod Classic Headphone Jack & Hold Switch Replacement
And depending on the model you have you can buy on of these replacement parts:
iPod Classic (Thin) Headphone Jack & Hold Switch
iPod Classic (Thick) Headphone Jack & Hold Switch
Good luck!
Nathan
iPod Classic (Thin) Headphone Jack & Hold Switch图片
产品
$9.99
iPod Classic (Thick) Headphone Jack & Hold Switch图片
产品
$29.99
这个答案有帮助吗?
得分 1
1条评论:
Thank-you so much!
完成的
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 961
