跳转到主内容
Model A1369, 1.6, 1.7, or 1.8 GHz Processor, 64, 128 or 256GB Flash Storage
328 个问题 查看全部
问题已关闭
How do I repair screen blacklight?
Hi,
I have a MacBook Air that works, the display work I am able to see the screen at a certain angle and with light, but the brightness doesn't work. It is completely dark., and I try to all the trouble shooting with rebooting and booting in safe mode and the problem is still here, so I'm wondering how would I fix this problem? Do I need to change the fuse, if so how would I do it?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Edward, you will have to check the fuse for continuity. Use a multimeter and see if it has blown. You also want to check the LVDS cable and the connector. Check closely for any damage. It is also possible that your wled driver has failed. To properly identify the location of the parts as well as the parts itself, post the last three digits of your serial number as well as a few good images of your logic board. This guide 在已经存在的问题里加入图片 will show you how to add images to your question. Hope this helps, good luck.
这个答案有帮助吗?
得分 1
添加一条评论
There’s no fuse or such a thing for this issue. It’s your back light. It’s gone. You need to change the light or whole lcd panel. Done.
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 592
