跳转到主内容
Released June 2009 / 2.53 GHz Core 2 Duo Processor
195 个问题 查看全部
Screen Case is Coming off
Hi People,
When i close my macbook pro the metal casing to the screen flexes out at the hinge area. When the macbook is close the metal casing sticks up.
I can't see why its started to happen and i can't see how to fix it.
The screen appears to be fixed fine to the hinge and doesnt move, its just the metal.
Can anyone help or tell me how the screen casing is attached?
Many thanks,
Chris
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个回答
已选择的解决方案
Ouch!
With a little pressure does the lid snug up with the base? If not something has been bent. I could see a pen or pencil being wedged and the lid is then folded as the cause in that case. If the lid does snug up then your display unit will need to be disassembled to tighten the hinge screws. The cause here is likely the assembler forgot to apply LocTite on the threads so vibration loosened the screws.
In any case I wouldn't move the cover to much as you could damage the ribbon cable.
You may end up needing replacing the full lid assembly if its damaged.
这个答案有帮助吗?
得分 1
评论:
Thanks Dan.
There's no damage and caused by a pen/pencil and yes it does snug up when a little pressure is applied.
So how do i go about fixing it or locating the screws to tighten?
Cheers
完成的
Thats good to hear its just loose screws. Follow this IFIXIT Guide to get the lid off and you'll need to pull the LCD panel off to get to the screws that how the other side of the hinge assembly.
完成的
添加一条评论
添加你的答案
Chris 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 4
过去的30天: 10
总计 1,148
