跳转到主内容
捷威所制造的台式机的支持界面。 现在捷威被宏碁的子公司,现在捷威所有新的产品都是宏碁公司旗下的产品。
40 个问题 查看全部
Gateway FX6860-UR20P won't recognize any of my Ethernet cables?
I just had my computer looked at by the geek squad, they fixed all the problems I was having with not being able to connect to airport networks. It lasted for about a week and started to decline, I decided to switch over to Ethernet so I route a cable from my modem to my computer and hooked it all up. To my surprise nothing occured, no pop ups, no connection. I booted up my Laptop to see if it was my cable, but when I plugged it in almost immediately it connected, provided better connection then just wireless. I'm not sure what the problem is and I'm not sure wether to build myself a new computer or see if geek squad can help again. If you need any more info just ask
My desktop - http://www.newegg.com/Product/Product.as...
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
Launch CMD
It will open a command prompt.. Enter this: ping 127.0.0.1
If you see Packets send and receive it means it's indicated to software issue which may be the drivers.
However, if you see fail or something else, it's hardware issue, that is! Your NIC is dead..
这个答案有帮助吗?
得分 2
2条评论:
Well it said ping is not recognized, So I guess my NIC is dead, I barely know what that is, but I know the name. Can I replace it? or am I screwed?
完成的
Then your network card is dead, just type NIC on ebay. It's around 5 bucks.
Good luck!
完成的
添加一条评论
添加你的答案
TravisC 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 5
过去 30 天: 13
总计 561
