跳转到主内容
修复你的物品
维修的权力
配件 & 工具
1.83 GHz Core Duo or 1.83, 2, or 2.16 GHz Core 2 Duo A1208 (EMC 2104/2110/2114/2124)
266 个问题 查看全部
Power supply compatibility (iFixit store)
I have a 17" intel iMac which has a pretty strange problem. Sometimes it works fine but it often doesnt want to start AT ALL (no light,....) This model has no led inside to diagnose the problem.
As it sometimes accepts to start up, i think that the motherboard is ok, and the power supply guilty. So, I would like to replace this part myself. My only question is the following :
Will a power supply owned @ iFixit work on a european (french) iMac ?
I mean, you americans use 110V/60Hz powerage and we use a 220/50Hz one. I wouldnt like to turn my iMac into a barbecue.
Thanks to everyone !
已回答! View the answer 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
Manta 螺丝刀工具包
日常维修的112个替换头
Upgrade Your Toolbox
Manta 螺丝刀工具包
2个回答
已选择的解决方案
Vincent Monteil, it is my understanding that the PSU is rated for 110V-240V 50/60HZ so it should work for the European market as well. Best bet of course is to get confirmation from the vendor. If you want to purchase it from ifixit I suggest to contact them directly on here. Hope this helps, good luck.
这个答案有帮助吗?
得分 1
评论:
That is a nicer answer ! Thanks !
完成的
添加一条评论
Be aware that this is the volunteer DIY help forum - we are not iFixit employees. To contact iFixit directly use the link at the bottom of the page.
If this answer is acceptable please remember to return and mark it.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Vincent Monteil 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 102
