跳转到主内容
苹果 iPhone 5c 于2013年9月10日发布。该设备的维修与以前的型号相似,需要螺丝刀和撬机工具。提供GSM或CDMA / 8,16,32 GB /白色,粉红色,黄色,蓝色和绿色。
1233 个问题 查看全部
Is the iPhone 5c charging port the same as the iPhone 5?
I need to replace a charging port on an iphone 5c (water damage) but i cant find this part cheap! I saw on ebay a few at $100 from USA sellers and $12 from chinesse sellers!! Which one is a real charging port for iphone 5c? I've been googling if i can use a charging port of an iphone 5, but nobody is talking about the iphone 5c or 5s reparations! Unless it is about the screen! Any advise?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
Just buy the chinese one, Apple parts are made in China anyway.
完成的
添加一条评论
4个答案
已选择的解决方案
No. The parts are different. They are visually identical from the port itself to the headphone jack, but the ribbon cable that connects to the logic board and the two pressure contact points are different. Unfortunately this makes the parts non-interchangeable. You can view both parts on the iFixit teardown for the respective devices.
这个答案有帮助吗?
得分 4
1条评论:
Another advert ..mostly for LCD's ... A check of the two charging ports for comparisson cannot be made as I only see the charge port for 5c.
完成的
添加一条评论
There's a difference, but it's possible.
If you use iPhone 5 charging port you also need the iPhone 5 homebutton flex, then everything will work ;)
I did already 2 iPhone 5c with iPhone 5 charging port.
这个答案有帮助吗?
得分 1
4条评论:
I dont get it! What is the home flex? I have a 5 parts phone amd a 5c acting up. What do i need to do?
完成的
The home button flex is on the 5s not on the 5. Nor is it on the 5c. They both have two pin connectors where two brass tabs from the screen side press onto two "Hooks" on the case/board side. I have to try this tomorrow so I will try both.
完成的
Can you use a 5c logic board in a IPhone 5?
完成的
iPhone 5 and 5c do not home button flex as such, they have a short connector with two tabs. They don't fit into anything , instead they are "pressed" against two "hooks" when they are assembled.
完成的
添加一条评论
The two charging ports are different. Start at the end of the flex cable. The iphone 5 has a piece cut out to fit a screw. The iphone 5C is oblong with no piece cut out. Beneath the speaker. (The square silver thing) The two contact points on the 5 are on oposite sides of the cable. The 5C has them both together .
Look at the headphone jack on the 5C it protrudes whereas the 5 headphone jack is flush and so won't fit.
Lastly is the screw Tab at the side of the headphone jack. The 5 Tab is right near the front whereas the 5c tab is halfway back. Either way you wouldn't be able to screw it down and for each you would have a screw tab in the wrong place.
这个答案有帮助吗?
得分 1
2条评论:
完成的
No, I will keep it simple, the connections are different places and orientations.
完成的
添加一条评论
can i use iphone 5s chargimg port on the iphone 5
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
asmodeus draco 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 24,746
