跳转到主内容
A sturdy 8.9" ASUS netbook designed for use by children. Product ID MK90H, available with a blue Mickey pattern or a "Princess Pink" print.
问题已关闭
Why is the screen black on my Disney Asus MK90H?
1. How to find the battery in this device?
Initially I have problem "plugged in, but not charging"
although the computer operates very well.
2. When I opened the box with screwdriver, I found the "RAM", instead of battery. After I closed the box that contain RAM, my ASUS computer could not operate again as before. It appears as "black screen" that I could not use it again. How to fix this technical problem?
Thanks for your suggestion.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
This video will show you how to take it apart and where the battery is which looks like a black rectangle.
You should also know the fans on these models are prone to failure so it is best to monitor the temperature.
The power issue sounds to me like a loose solder joint but could be many things including the power supply or even software/hardware battery management letting the netbook know it is plugged in.
It is possible you dislodged the ram when opening.
http://www.youtube.com/watch?v=ZFlZ2dweL...
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 264
