跳转到主内容
Fourth generation of CDMA iPad 4. Available in 16, 32, or 64 GB models. Model Number A1460.
20 个问题 查看全部
iPad 4 Logic Board Schematic - Backlight Circuits
With the understanding the the complete schematic would be illegal to post, I'd like to see if someone could post a picture of an iPad 4 logic board with the various components of the backlight circuits highlighted and ID'd.
Any additional information that could be provided (like coil, filter and voltage chip specs) would also be greatly appreciated.
I'm working on repairing an iPad 4 that has a faulty backlight circuit, and although I've seen a few pictures on YouTube and on CyberDocLLC, I've yet to see a good picture of the actual iPad 4 motherboard with the components properly id'd and labeled with respect to the specific backlight they are controlling.
The reason I'm asking for the chip specs is so I can order 10-15 of them.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
2条评论
this answer is available from WitesOmTesla, but it is not free.
jessa
完成的
fhhowdy, post some hi-res image of your logic board. I might be able to assist you in your quest. I am looking at most of the schematic right now but need to make sure it'll match
完成的
添加一条评论
1个答案
最有帮助的答案
Apple doesn't label any components on the board, and the trace is mostly buried in the internal layers of the PCB. It is not possible to figure out how it works without the complete schematics. I only have ipad 3 schematics so I doubt ipad 4 ones are not yet available.
If you are still interested, Ifixit and chipworks have taken very high detailed pictures.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
fhhowdy 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 3
总计 2,563
