跳转到主内容
型号A1367,闪存容量:8、16、32及64GB
915 个问题 查看全部
Home Button Won't Work Even After Replacement
I was fixing an iPod and the home button stopped working. I decided I'd purchase another home button, but even after it still will not work. The button clicked and everything, even the original one seemed like it was in perfect condition. What can I do? I even put it on another iPod and it still didn't work. What could be the problem?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
最有帮助的答案
Did you replace the physical button or the flex cable that sits underneath the home button? If you haven't replaced the home button flex cable, try that first. If you have, check to see if the metal shield that the home button is attached to isn't warped to where the contacts on the button of the flex aren't contacting the motherboard.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
lelis fairelough 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 2
总计 126
