跳转到主内容
修复你的物品
维修的权力
配件 & 工具
An external hard drive that uses USB 2.0.
5 个问题 查看全部
Takes some time for my mac to see my hardrive
I had this harddrive for quite a few years and now it takes ALOT longer then for it to read on my mac then in 2006
also i use it on my dell at the same time but NEVER on both computers
i used it on my santa rosa MacBook Pro in 2008 sometimes but i got the meachine upgraded
it is a 250gb
已回答! View the answer 我也有这个问题
这是一个好问题吗?
得分 0
评论:
What connection type is it?
完成的
As well as what format?
完成的
it is a usb2.0 and it works on my mac and pc on fat32 i believe
完成的
添加一条评论
Manta 螺丝刀工具包
112 bits for every fix.
Upgrade Your Toolbox
Manta 螺丝刀工具包
4个回答
已选择的解决方案
Have you tried re-formatting it with your disk utility application? My external drive wouldn't even register until I re-formatted it into the Mac OS(Journaled) version. I'm guessing that is your problem, but get back to me!
这个答案有帮助吗?
得分 0
评论:
that would make not that much sense - the drive is used on a mac and a pc. i never had any issues with a fat32 drive and mac os - the mounting speed can be slower when the drive is large, fragmented and/or full.
完成的
All I'm saying is my GreenDrive would take about an hour to mount then it would disappear and all my problems went away when I re-formatted it. I changed the format type to Mac OS (Journaled) and it works perfectly now. I thought that this guy had the same problem.
完成的
添加一条评论
最有帮助的答案
How full is the hard drive ?
maybe it needs to be defragmented
do you use the drive very often ?
4 years can be a long time for a hdd
这个答案有帮助吗?
得分 2
评论:
I guess you mean 147 out of 160gb - in that case i would say - the drive is almost full (160gb should be around 149gb in reality). since it's a 160gb - is it a 2.5" ?
完成的
its a 3.5''
完成的
I pulled it away from my dell to check and get a correct use
完成的
My mistake theres 245GB left on it
完成的
添加一条评论
Well, you can't re-format it in a different filesystem and maintain mac compatibility, since FAT32 filesystem is the only filesystem, that can be read and wrote to by both Macs and PC's, but you could try and defragment it as Markus Weiher suggusted. also, have you opened the drive enclosure, and checked for dust, or anything preventing the cooling mechanisms from working? When drives heat up, they tend to slow down. If it still gives you issues, i would backup your data, as the drive may crash.
这个答案有帮助吗?
得分 1
评论:
and by the way i think it disapates heat naturally and i took it apart a while back and it uses heatsinks too
完成的
it has a thin layer on the heatsinks
完成的
添加一条评论
Slightly off topic but maybe its a case of "Holmes we have a clue". My MacBook Pro (2.16 C2D) used do really boot quick into 10.6 (40secs) but with time it got a lot slower. Recently i installed a new 250 GB drive and restored everything from a TimeMachine backup. Since then it is as quick as it used to be.
这个答案有帮助吗?
得分 0
评论:
its a external drive
完成的
添加一条评论
添加你的答案
Nick 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 1
过去的30天: 1
总计 953
