跳转到主内容
The fourth Google Nexus smartphone, released November 13, 2012.
75 个问题 查看全部
Nexus 4 screen regularly blacks out when make a call
The screen on my Nexus 4 regularly blacks out when I make a phone call. This has got worse since I had the screen replaced recently. I can hear the call but I cannot then use the screen to switch to speaker and worst of all I cannot disconnect the call. If I keep intermittently pressing the on/off button the screen will flash intermittently and if I keep hitting where the disconnect bar is I can after a while hit it just at the right time and I get my screen back. Nightmare! Is there a remedy to this fault?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
6个答案
Its not actually a fault, its so your phone doesn't start ending your call or changing things when its pressed up against your face, as this activates the touch screen similar to when your fingers move across the screen. If you remove it from your face and wait a few seconds at most it will switch the screen on again and you can end your call.
这个答案有帮助吗?
得分 0
1条评论:
well let them know they are stupid and that makes their fones just as stupid like they are. nice when the government or the bank ask you to press 1 or 2 0r 3 ect... and you cant. super duper stupid fone
完成的
添加一条评论
You CAN make it so that lock button ends your call in settings, have a look under settings for how to do this or do a quick Google search :)
这个答案有帮助吗?
得分 0
1条评论:
oh nice. so you end your call with the goverment you waited half hour to reach when they ask you to press numbers. very smart cell crap.
完成的
添加一条评论
the problem is associated with the proximity sensor. in order to fix it just remove the screen protector from that region. mind you it is not a software or hardware problem. its just the type of proximity sensor in the nexus 4. due to this you are advised to use thin screen protectors or just avoiding the sensor area.
trust me it works.
这个答案有帮助吗?
得分 0
1条评论:
and how the HECK you do that?
完成的
添加一条评论
Do you use a display foil? If yes, check if the foil covers the distance sensor in the upper left of the phone.
这个答案有帮助吗?
得分 0
1条评论:
wtf it all mean?
完成的
添加一条评论
I have had the same problem also since replacing the screen.
I am not certain but i think the problem might be a screen protector on the inside sensor porthole - one which needs to be peeled off before installation. I tried doing this before fitting the new screen but couldn't just peel it off. I ended up sort of scratching it off badly with some bits left behind.
Either way it still didn't work for me but if what people say about screen protectors is anything to go by this could be an issue.
这个答案有帮助吗?
得分 0
添加一条评论
The remedy is a weird one.
You must remove the logic board. When you do this you will see the proximity sensor on it has a black rubber covering with two holes. One big and one small.
Take the rubber covering off and flip it.
I'm not sure why it works, but I've used this to fix this problem dozens of times
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jashim Quraishi 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 2,539
