跳转到主内容
7.9 inch display / Model A1454 / Available in black or white / Announced October 23rd, 2012 / 16, 32, or 64 GB capacity
28 个问题 查看全部
missing 2 elements on motherboard LCD is black, backlight is ok
A1455
after replace digitizer i have no backlight. after make jumper baclight back on place but LCD dont show anything. after i open case of motherboard i will see that 2 elements missing. can anyone help me in check which elements missing capacitor or resistor and what is value of this elements. thx for help
http://nextserv.pl/images/missing_elemen...
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
1条评论
Hello, I had almost the same problem: Problem with the LCD after replacement
przemohebel did you solve this?
完成的
添加一条评论
2个答案
最有帮助的答案
what happened to this one? Those components can totally be replaced and this iPad mini will live.
It is odd that in your inset the two big caps are obviously missing (and yes, the one on the left is required for the image production voltage---don't have schematic on this laptop or i'd post the details of it)--but the component, as well as the backlight fuse, is present in the other image.
这个答案有帮助吗?
得分 1
添加一条评论
Is this your phone or a job for someone else? I dont understand how parts from the motherboard could just be missing try looking up images of that motherboard and comparing if it worked before you repaired it then it stopped working suspect yourself if it was already broken and you dont know why and its not your phone then look for another to compare it against somehow. Ive seen tons of boards that look like they have components missing but thats just what it looks like.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
przemohebel 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 876
