跳转到主内容
修复你的物品
维修的权力
配件 & 工具
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
3030 个问题 查看全部
Why is there white spotting going through lcd?
Hello,
I just replaced the front lcd assembly (lcd, digitizer, backlight and frame) and was VERY careful throughout. When pressing the home button and around the home button on the white part of the glass, and pressing towards the upper part of the screen, white spots shine through. They go away when removing finger from screen or holding finger in that position, they will also fade away.
It is for a friend so it is driving me insane!
Hope you can help.
已回答! View the answer 我也有这个问题
这是一个好问题吗?
得分 0
评论:
Update: when having the back cover removed, the problem is almost next to gone unless I pressed abnormally hard. Back cover must not be a perfect fit and is pressing the backlight against the lcd?
完成的
添加一条评论
LCD iPhone 屏幕维修套装
预算选项,涵盖在我们的终身保修中。
购买套装
LCD iPhone 屏幕维修套装
削减维修成本,而不是质量。
购买套装
3个回答
已选择的解决方案
Hello zentech this is caused by the battery been slightly bent and formed a tad out of shape cause when you put the back cover on it puts stress on the lcd underneath
I would take out the battery and also the adesive that held the battery on the frame could be sticking up... Try this and it will 100% work
Take off the adesive on the mid frame that held battery and also the whole plastic pull tab cause you don't need it and straight out battery and make sure nothing is stuck to it..
Do this and problem solved :)
这个答案有帮助吗?
得分 2
评论:
Great advice as well! Thank you. In the process of putting the phone back together atm. That's funny because the battery did bend a bit on removal, oops! Apple sure makes a tight fitting phone with even a slight component out of place and you get screen issues. Will update with results!
完成的
No probs lets is no
完成的
Made a HUGE difference, almost perfect! There's a BIT of space between the the back cover and the iphone framing, almost looks like a half mm bend. I know I had to press the speaker in a bit. Going to tinker around there.
完成的
I have removed the speaker and there are NO issues. It was not sitting right somehow. Cleaning up the battery fixed some of the spots to begin with as well. Thank you!
完成的
Glad this helped it's just the battery putting pressure on the lcd
完成的
添加一条评论
Sounds like a cheap bad screen,, hopefully you can exchange it for a good 1.
这个答案有帮助吗?
得分 0
添加一条评论
The screen is not seated correctly, you may have left on the plastic protector on the back of the screen, also check to make sure you have all the screen screws installed and tight. If you are still having problems you should check the frame it could be bent.
这个答案有帮助吗?
得分 0
评论:
Thank you, I will reassemble it with your advice.
完成的
Resolved a small issue with the home button, cut some of the new adhesive I put down around the home button rubber and it now clicks like new! So far no screen issue! (system is barebones atm, battery, board, and lcd)
完成的
添加一条评论
添加你的答案
zentech 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 130
