跳转到主内容
doesn't wake up after closing the lid
Hi guys !
recently after i close the lid of my macbook pro 13" when i open the lid computer doesn't wake up from the sleep. i have done all the SMC reset , NVRAM , PRAM , fresh install the OS and none of them work . so u i have to hold teh power button in order to turn it on back again. what could be the issue ?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
4个答案
已选择的解决方案
You could damage your HD if you continue to crash (force start) the machine. Every time you catastrophically, instead of gracefully, shut down the drive you fragment the MBD. Do that too many times and it will not recover.
You haven't mentioned the OS. You haven't told us if you've been inside the machine and didn't reassemble the sleep magnets correctly. Two pieces of information we need to offer successful solutions.
Follow the tags at right for some steps to check.
If this answer is acceptable please remember to return and mark it.
这个答案有帮助吗?
得分 1
1条评论:
hi there
thanks for your reply
i have tried installing mountain lion and Lion to see if it can fix the problem but it didn't . currently the machine is on lion . i have opened the the bottom cover but i just removed the battery and put a new battery but it didn't fix the problem . i have no idea where those sleep magnets are located can you explain further.
完成的
添加一条评论
Actually I'm having the same exact problem. My Mid-2009 MacBook Pro 13.3 inch goes to sleep permanently after closing the lid. I will open the lid up and the light is still pulsing, but when I click the power button nothing happens. I have to hold the Power button until he machine has turned off, then click it again, sometimes for some odd reason it will continue with resume, or it will re-boot. I have already reset the SMC, and PRAM. No luck at all. Once the lid is closed you can't have it recover from sleep mode by pressing a key or clicking the trackpad.
这个答案有帮助吗?
得分 1
添加一条评论
I have the same problem as Jabran. Have confirmed that resetting SMC, PRAM, reinstalling Mavericks did not help.
这个答案有帮助吗?
得分 1
8条评论:
Without connecting your system to an Ethernet or WiFi network, see if the date & time hold and are correct (you don't want your system to access the internet time server). If you are loosing time or the date rolls back the PRAM battery is dead. Depending on your model it could be a discrete battery, capacitor or clock unit soldered onto your logic board.
完成的
Yes Dan,
The date does roll back.
I know these are different from the old days of seeing a battery that I can replace. Will this discrete battery, capacitor, clock unit need to be soldered on?
完成的
Can you give us the last four digits of your serial number so we can narrow down which model you have.
完成的
The last 4 digits of the serial number of the laptop is 966H
完成的
显示更多的3条评论
添加一条评论
The problem may be due to SafeSleep, which is enabled by default on Macbooks and causes the laptop to write out the RAM to disk when put to sleep. Try turning off SafeSleep and see if that helps. My 2011 Macbook Pro started hanging occasionally when closing the lid after I upgraded to 8GB RAM, and turning off SafeSleep seems to have stopped it.
How to Turn off OSX SafeSleep
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
soroosh 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 20
总计 24,346
