跳转到主内容
Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1203 个问题 查看全部
Display Backlight bleeding on 2/3 of lcd screen. what to replace?
I bought a used 2009 13" a1181 2.13 ghz MC240ll/a macbook on ebay. Everything works except lcd appears faded out on left upper corner and right lower corner. The fading is irregularly shaped and worse on the left and takes up about 2/3's of screen. It's not that bad and the computer is useable. But it is annoying. It does not change with length of time computer used or moving screen. It did not fix with PRAM reset or with reseating display cable on logic board. Video looks fine when hooked up to external monitor. Would I need to replace whole display to fix or can I just replace video cable? Or could it be inverter board? Any more trouble shooting I should do?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
I can think of no reason a controller or cable would cause this problem. I believe the LED display has some bad/damaged traces at the edge(s). Have you run AHT?
If this answer is acceptable please remember to return and mark it.
这个答案有帮助吗?
得分 1
1条评论:
I don't have install dvd; so am not able to run AHT. Sounds like I would need to replace LED display to fix then.
完成的
添加一条评论
添加你的答案
barelymd 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 461
