跳转到主内容
The PlayStation 3 (or commonly known as the PS3) is the third home computer entertainment system produced by Sony Computer Entertainment, and the successor to the PlayStation 2. It was released November 11, 2006
781 个问题 查看全部
Repaired yellow light of death, works shortly then shuts off
I followed all the steps recommended when replacing the thermal pads and reheating the mother board. Once reassembled it worked for about 2 hours. I then turned it off. The next day when I started playing it lasted about 5 minutes then shut off. And now basically when I turn it on, it'll turn off shortly after. Not sure if there is anything left for me to do except buy a ps4, but i'd like to fix it if possible
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
I hate to break it to you, but the time that fix will last varies on each system. A friend of mine had the same problem, so I performed a similar fix, only to have him report two weeks later that it stopped working again. I was a little more rigorous in the fix and I found that does seem to make a bigger difference, but no matter how many times you try it, the problem will never go away.
The only long term solution to this problem is to perform this once again, never turn off the system, and hope for the best. Unfortunately the longest I've heard this method lasts ranges between 3-5 months.
If you do decide to do something like this, you can try my method:
1. I prefer to set my heat gun to high and give 10 seconds to the memory and 15 seconds to the CPU and GPU.
2. Let the board sit for no less than 15 minutes to give it time to cool, and do the same process to the other side of the board at the same approximate locations.
The PS4 unfortunately does not accept any PS3 games and has a terrible selection of Local Multiplayer games so if you are like me, dishing out ~$150 for a replacement system and waiting until game developers come out with game worth playing is not that terrible. Sony did announce support of the PS3 for the next two years, so you will see new titles like destiny for the PS3.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
svensorhus 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 172
