跳转到主内容
加入维修社区 - 创建账户
iPod Classic 第六代。机型型号 A1238,80、120 或 160 GB 机械硬盘,黑色或银色金属前面板。
Battery won't charge up - only works when plugged in.
Hi,
It got to the time when the battery needed to be replaced, or so I thought. I took it to a repair shop who installed a new one, after which they told me I was good to go. Once the battery had reached its max paying time, I plugged it in (for several hours)for it to recharge. However, when it came to unplugging it in view of listening, again the battery stated it was out. I tried different chargers, both through the mains and a computer. So, I brought it back to shop where I left overnight so they could take a look at it. The next day, I returned to find that they had tried multiple batteries but the device still wouldn't charge. I can now only as a consequence listen to it plugged into the wall. I suspect there is something wrong with the motherboard but not too sure. Can you help?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 10
5条评论
I have currently attached your question to the page for the 5th Generation iPod Video. Let me know if your model is this one, or the 6th Generation iPod Classic, since both have 80 GB versions and video capabilities.
完成的
Actually I think it's the 6th gen classic. I always get mixed up!! Thanks.
完成的
I have an ipod apple. My friend gave me a charger at school that was worn out but charged my ipod for some reason. Oh wait but it didnt charge, ive used all the chargers i could find and my ipid was having a heartattack like it wuz trippin cuz. Please help
完成的
I have the original one from around late 90's. Only works when in docking station. Can't use it with headphones, like at the dentist office.
完成的
I have an iPod classic, Model # MBO29LL Version 1.1.2 PC.
The battery won't charge. Do you replace batteries?
My email address is douglasogle@gmail.com
Thank you./
完成的
添加一条评论
5个答案
已选择的解决方案
Hi,
i had a similar issue with one of my iPod classic and in my case a new logic board fixed the problem.
这个答案有帮助吗?
得分 6
添加一条评论
Most have power mosfets, I believe that's what they call them. Look on cyberdoc. It is a small chip apple likes to use that goes out and needs to be pulled from the motherboard and the contacts joined with solder. This usually fixes the no charge problem . Bad batteries usually just die fast. They still charge and last a little bit.
这个答案有帮助吗?
得分 3
添加一条评论
Just get a new battery.
-Me-
这个答案有帮助吗?
得分 0
1条评论:
possible solution - but since the shop "tried multiple batteries" - it could be a different problem
完成的
添加一条评论
If it won't hold charge, and did with the old but worn battery, possibly something happened during the repair. Could be that the motherboard has been soiled or corroded. If so there is a chance that it can be cleaned (I managed when my iPod had similar symptoms).
You could go to the shop a tell them that the malfunction started after the repair, and would they accept responsibility. When they answer no, ask if they could - only from their wish to be helpful - give you a cleaning liquid plus instructions (there is repairmanuals on this forum if they prove to be completely uncooperative).
Several cleanings might be necessary. Focus on the area closest to the battery ribbon cable connector.
Good luck
这个答案有帮助吗?
得分 0
添加一条评论
I have the identical issue. I have a ipod classic 5 modded with a 256gb SSD and had a 2000mah battery. It never charged. Replaced the battery at a local tech shop with the standard battery. Still not charging. I have it rigged to a 5000mah battery pack which fits in my hoodie pocket so its portable. This has the wolfson DAC and sounds better than my phone and other DAPs.
I image whatever charges the battery, that is regulates the charge needs to be replaced.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Marc 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 32
总计 77,796
