Mid 2006 / model number A1181 / black or white case / 1.83 or 2.0 GHz Intel Core Duo processor.
516 个问题 查看全部
Screen goes black after lifting halfway.
I can lift the screen halfway up and it works fine. After that black. I've never tried to repair a computer in any way. Where can I even begin to learn how to repair this on my own?
已回答! View the answer 我也有这个问题
这是一个好问题吗?
按维修分数 0
添加一条评论
所有超过US$100.00或包含 Pro Tech工具包的订单免费送货!
浏览我们的商店
善于维修,即天赋异禀。
与 #ImAGenius 分享您的维修故事
我们都是天才
1个答案
已选择的解决方案
You study (not just read) the guides and comments for the particular problem… in your case it sounds like loose clutches (Mac speak for hinges) have cut or nicked a cable or two (inverter - data display cable). The cables might be "fixable" with some silicone… or they may need rerouting and/or even replacement.
Just to ensure that it' not logic board or GPU/VGC related connect an external monitor… it should not lose its signal.
Obtain the proper tools - every job is easier when you use the proper tools.
Come back here and post comments or update your original question for more assistance.
If this answer is acceptable please remember to return and mark it.
这个答案有帮助吗?
按维修分数 1
添加一条评论
添加你的答案
guitarjt 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 62
