跳转到主内容
第四代iPhone。维修过程直观易懂,但前置玻璃和LCD面板无法分开,只能作为同一零件更换。GSM版本, 8, 16, or 32 GB 容量 / 型号 A1332 / 黑色或白色
3299 个问题 查看全部
water damage and after problem
Hello, my iphone was recently water damaged. I ordered new iphone screen and body except the main board.
I replaced the whole things. but here is a strange problem occur
1. when I connect the iphone to the charger. It goes to the main page but when i disconnect it iphone turned off.
2. Iphone want me to connect to the Itunes before it goes the further process. so when I connect it to my computer. it failed to connect to my computer and turn off before it goes to the main page.(turn off and on constantly)
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
评论:
If you have cleaned the board properly and changed the battery, replace the dock connector next.
完成的
添加一条评论
2个回答
最有帮助的答案
If phone works on charger but not off charger check to make sure battery connectior at logic board isn't loose/damaged. The socket is easy to accidentally liftoff the pads and show the behavior you're describing.
Jessa
这个答案有帮助吗?
得分 1
添加一条评论
You need to take it to a repair shop or clean the board yourself. The battery also always need to be replaced when it is water damaged.
这个答案有帮助吗?
得分 0
评论:
I bought the new battery, and I clean the board with revive iphone.
the problem is that computer does not recognize the iphone itself
完成的
添加一条评论
添加你的答案
jake 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 56
