跳转到主内容
问题已关闭
Won't play disks - blank display!
The power LED lights up, drawer works perfekt, i can hear the disk spinning inside. But nothing on the display and no output. Any idea?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Is there absolutely nothing to see - no lights at all?
i had the display problem a few years ago with my dual studio concept - when i "flicked" slightly on the display - it came back
did you check the laser ?
maybe you should clean it with a soft cloth - dust can be a real pain on those drives
这个答案有帮助吗?
得分 0
2条评论:
Thx, i try the cleaning first. Does the display only comes to life when a disk is detected? I'd exspect it to say something like "No Disk".
完成的
those displays should show a sign of life when you power on the device - not that there must be anything "readable" - only a noticeable light.
check the display connection when you clean the laser (nimm am besten ein microfaser tuch zum glserpolieren, die dinger sind genial)
完成的
添加一条评论
Closed - I just sold the bugger.
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 2
总计 1,942
