跳转到主内容
Microsoft Surface Pro 2 是一个2013年发布的二合一平板笔记本解决方案。 Surface Pro 2 是 Surface Pro 的继任者,预装 Windows 8.1 并能升级到 Windows 10
CMOS backup battery inside Surface
Has Surface Pro 2 a CMOS battery?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
No, the board is always powered by the main battery.
这个答案有帮助吗?
得分 3
2条评论:
ah ok, thank you! ...so it is quite normal that if the main battery is completely empty the system does not autonomously move forward the date and time (without sync with a NTP server).
完成的
This is actually very rare and potentially dangerous. Products with built in batteries have a "hot battery bus" that is always powered when the battery is connected. It manages the clock and power on standby modules. This should consume minimal power so even if the battery is so low that it refuses to power on, the hot bus should work properly for months. Discharging the battery too much causes irreversible damage to the battery, it may even trip out to block charging forever. So avoid leaving the device uncharged for a very long time.
完成的
添加一条评论
添加你的答案
MfCAYO 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 3
总计 4,994
