跳转到主内容
Updated version of the original iPad 2, released in March of 2012 with a smaller die processor and updated internal construction. Repair will require the use of heat and careful prying.
73 个问题 查看全部
Is there any differance between 2415 and 2560 lcd
My ıpad 2 (2560) lcd was broken.I changed the LCD, but I did not take any display on the screen except horizantal color lines.
Is there any differance between 2415 and 2560 LCD panels.May be I used to wrong one.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
最有帮助的答案
It's more likely that you didn't seat the cable correctly. Try reseating it. DON'T close up the screen until you test it and it works, as taking it apart is difficult and the more you do it the greater a chance that it will break.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
cem kutlu 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 461
