While turning on my computer it freezes at a black screen?
after i power it on all of the buttons turn blue like always and then about 2 seconds later it freezes at a black blank lit up screen. please help all family pictures are saved on there.
This is usually a bad GPU with the 2007 DV series and this is usually the common failure point that tells all. However, it can also be a bad LCD but this is rare. To verify, plug it into a monitor and see if it locks up or does the same thing — if it does the GPU is bad, if not bad screen.
When this happens, the laptop is toast. Get your data off and scrap it or give it to someone to strip for parts. The problem is caused by poor cooling and the problem still occurs, even with the upgraded heatsink which requires the revised motherboard to install since the GPU placement changed as a part of the “fix”. HP only acknowledged fault when they were sued and only covered one of the 2 bad machines. Their “fix” was a hack to shut the lawyers up and it did absolutely nothing to stop new failures outside of absolve them of new liability.
If the GPU is so bad the machine is beyond Safe Mode recovery, the hard drive(s) need to be removed. You can save these as your backup, but I’d really recommend copying the data off to another drive as these drives can fail. This is what I did on a DV9000 (factory dual drive configuration), but the procedure isn’t any different on single drive machines.
这个答案有帮助吗?
I had two of these and both times the gpu went on it, they run too hot so the gpu either fries or needs reballing. It's possible sometimes to rescue them by reflowing the gpu with a heat gun, this melts the solder again and fixes any dry joints.
To get your info off the laptop you can try plugging it into a tv or monitor with a VGA / monitor cable, as a lot of the time you can still get a picture on the monitor when you can't on the laptop screen, I know this was the case with both of mine that died.
这个答案有帮助吗?
ive had the same issue for me it was the lcd inverter went out so the black screen was actually the screen going dim i could barely notice the windows startup if i put the brightness to max.
这个答案有帮助吗?
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 4
总计 3,998
