跳转到主内容
第四代iPhone。维修过程直观易懂,但前置玻璃和LCD面板无法分开,只能作为同一零件更换。GSM版本, 8, 16, or 32 GB 容量 / 型号 A1332 / 黑色或白色
2375 个问题 查看全部
iPhone 4 left side of touch dead
i have a ip4 mainboard i would like to get working again.
The touch on the left side is unresponsive on all the screens i connect, so it is a mainboard issue. i have heated to mainboard to 150 degrees on a preheater, cleaned the connector with spirit, restored. no luck.
Have anyone got a solution for this? i have a bunch of defective mainboards to take parts from.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
This is way out of my league. But look very closely (high mag. if you can) at the digitizer connector on the logic board. See if any pins are corroded, damaged, missing. If the logic board connector for the digitizer flex is faulty, this would be a relatively easy fix.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Kjartan Eide Huseklepp 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 82
