跳转到主内容
Model A1237 or A1304 / 1.6, 1.8, 1.86, or 2.13 GHz Core 2 Duo processor
312 个问题 查看全部
New SSD installed not recognized. Incompatible?
I've just swapped out the original 120GB non-SSD from my A1307 (2009) Air, with a 1.8" Toshiba LIF SSD 128GB.
Any reason why it wouldn't be compatible?
The model is THNSNC128GMLJ by Toshiba. It's 1.8" and has a LIF-type connect.
There's a similar model that I've seen listed on eBay as compatible with the 2nd/3rd generation Airs, but it's model number is slightly different: THNSNB128GMLJ (the difference being a B in the model number, instead of a C).
Any help greatly appreciated. Thanks.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
Could be that the drive is SATA II and you need SATA I - I did a quick Google search and could not find any specifications for this drive… even at the TOSHIBA portal.
Generally SATA drives can drop back one rev and work… if it's more than that you either have to manually jumper them down, or, it's impossible to get them to work.
If this answer is acceptable please remember to return and mark it.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Matt 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 927
