My samsung won't charge, and isn't the battery's fault.
My phone was working fine, and charging fine, but when i woke up in the morning and went to check my phone the battery was at 35%. I unplugged my phone, and then plugged it back in. I waited a couple minutes and then when i checked it, it still wasn't charging. I took my battery out and put it back in after 15 min, and tried again... still nothing. So i took the battery out again and took the battery out of my cousins phone (Same exact phone,) and it still wouldn't charge. I tried plugging his phone in with my battery and it worked fine. So, what should i do? Also if i do need a repair, around how much would it cost? Thanks everyone!
42条评论
Yeah, mine stopped being able to charge only a few nights ago, and I have bought a replacement battery, and still nothing. I have used someone elses charger that works fine for the same model of their phone. I cleaned out some lint with a toothpick, and still nothing.
由 Holly Halestrap 完成的
I just recently got a new Samsung and it won't charge and I just got a new battery for it...any suggestions?
由 Chase Davis 完成的
My Samsung S3 suddenly stopped taking a charge. The lightening bolt was on but the battery level was decreasing! Eventually it went down to 9%. I searched online: changed chargers, changed cables, gently cleaned and blew air in the female contact, changed batteries...nothing. Then I tried charging from my laptop and its working. Great. But now what when I want to charge from the wall outlet again?
由 Ralph Rey 完成的
I kept surfing for solutions and came to this one by Jens Persson. He said ...
"Solution:
-Turn the phone off
-Remove the battery
-Wait 10 seconds
-Plug in the charger
-Insert the battery
-Turn on the phone (in my case, just held down the power key for a few seconds then it showed charging, finally!)"
Thanks Jens Persson, that solutions worked perfectly...I had already tried everything else to no avail but that method worked!
由 Ralph Rey 完成的
Thank you, Jens and Ralph. This method works a treat. Annie R.
由 annierizk 完成的
显示更多的37条评论
